Audio Cable or Subwoofer/non subwoofer cable???
By kryngle · May 04, 2007in General💬 5 posts👁️ 707 views
Posted May 04, 2007 · 04:06 UTC#1
Hi, I jus installed my D3 in and everything works great. Gotta ask tho, I have a 1000watt amp along wit a 15" sub. When connectin it to the D3, should I connect it to the Audio cable or the Subwoofer/non subwoofer cable? Thanks.
Oh and wit the bypass, I swapped the mute wire and grounded it but it won't let me watch the movie while drivin. Where should I ground the mute wire on a 2001 Civic EX???
Posted May 04, 2007 · 10:52 UTC#2
subwoofer/non fader
you also have to ground the parking brake wire
Posted May 04, 2007 · 13:24 UTC#3
Hey thanks man but one last question. Even tho I already hooked up my system the "normal" way, all I have to do is cut the light green wire(parkin brake) and then ground it???
Thanks in advance
Posted May 04, 2007 · 17:23 UTC#4
ground the parking brake and the mute wire you moved
Posted May 05, 2007 · 00:03 UTC#5
subwoofer/non fader
yes, along with the repinned mute wire
