Avic-D3 in '03 RSX --do I need a dash kit?
By gmoney863 · May 04, 2007in General💬 12 posts👁️ 2,048 views
Posted May 04, 2007 · 15:42 UTC#1
Does it fit perfect, or will I need a dash kit? I like clean, perfect installs :)
Also, if anyone has an rsx, what are the best mounting points for the xm and the gps?
Posted May 04, 2007 · 16:36 UTC#2
Type s or non type s. The type s needs a kit the regular one doesn't
Posted May 04, 2007 · 20:37 UTC#3
IT's a non type-s--are there any gaps?
Posted May 04, 2007 · 21:04 UTC#4
Depends on how good you are at cutting the trim piece that comes with the d3. If you don't want to do that you can get a 99-7801 and use that trim piece. No cutting/filing needed.
Posted May 05, 2007 · 00:57 UTC#5
Can you post a pic of your dash. Is your hazard button built into the radio bezel?
Posted May 05, 2007 · 01:00 UTC#6
It is on the type s aand isn't on the non type s
Posted May 05, 2007 · 15:14 UTC#7
So with this dash--if i'm not good at cutting trim, am I going to need a dash kit? Will the 99-7801 work perfect? This will be my first install so i'll probably order the 99-7801 with the tools.
Thanks again, guys!!
Posted May 06, 2007 · 00:24 UTC#8
Yes get the 99-7801 then.
Posted May 07, 2007 · 00:31 UTC#9
Another ques--where are the best places to mount the xm antenna and the gps antenna on the rsx? There is already some kind of antenna (a little rubber fin) on the top of the car, can that be used somehow? or is that just the fm antenna?
Posted May 07, 2007 · 12:13 UTC#10
Thats the fm antenna. For best reception they go on the outside of the car. If you don't want to do that a lot of people put them on the dash.
Posted May 08, 2007 · 15:17 UTC#11
I bought this car from a friend--and now that i think about it, he might have done the type-s dash kit--isn't the picture I posted a type-s dash?
Posted Jun 14, 2007 · 19:46 UTC#12
The "fin" on top of the car is actually the washer nozzle for the rear window. The factory FM antenna is integrated into the rear window.
-t1mb0t
