VSS wire on 2005 Nissan Pathfinder
By dkardell · May 05, 2007in Vehicle Specific Wiring💬 4 posts👁️ 1,824 views
Posted May 05, 2007 · 22:16 UTC#1
Posted May 06, 2007 · 00:38 UTC#2
Speed Sense lt. blue 8P radio harness or cluster, pin 6
Notes: May not be present on vehicles with base level audio systems.
If the wire isn't there behind the gauge cluster you can insert a wire into pin 6 to get vss too.
Posted May 07, 2007 · 16:08 UTC#3
Thanks for the reply but I'm not that savy on car wireing lingo...
blue 8P radio harness or cluster meaning the same one I spliced into to hook up the rest of the radio (meaning the original harness).
Pin 6 is what pin. How are they numbered? The SUV came with a base level audio system, but had an N2 in it until last month when it was stolen.
What does this mean.. how do you get to the guage cluster.
Sorry if these are easy questions. I am program a computer, but this wire thing is not as clear.
I have th Z2 all hoooke dup.. I just wanted to do the VSS so that I don't get the drift before the sat images lock in.
Posted May 14, 2007 · 14:35 UTC#4
Can someone help describe where this is?
