wires for 2007 camry
By lopester02 · May 06, 2007in Vehicle Specific Wiring💬 4 posts👁️ 1,376 views
Posted May 06, 2007 · 04:27 UTC#1
couple questions for 2007 camry with the JBL system
On the Metra harness i got tyto-01...it says to connect the blue/white wire to the amp turn on wire of the aftermarket radio...is that the same as the system remote control that is also blue white...and if so can i just cut off the plug thats on there and solder the two together?
Also...the antenna is in the glass so is there a cable behind there that i connect to the antenna cable on the harness or is that not needed.
Thanks...i have just not been able to take stock radio out yet.
Posted May 06, 2007 · 05:07 UTC#2
Yes and yes. The blue/white of the avic goes to the blue/white of the tyto-01. There should also be a blue wire on the tyto-01 which the blue wire of the avic should get connected to.
Posted May 06, 2007 · 12:51 UTC#3
i did not see a loose blue wire on the tyto....just had the blue/white, ground, yellow and red.....is the solid blue supposed to be for the antenna?
and you did say i can just cut that one end off right?
Posted May 06, 2007 · 13:22 UTC#4
If there's no blue, then don't worry about the power antenna must get turned on the same way the amp does then. And yes you can cut the connector off.
