Hey Guys,
I have sign up for xm nearly three weeks now and i am tried of calling to resend the signal.It only last for a day or so before it gome again.I have the pioneer xm unit with navtraffic.I don't loose the traffic channel.
Hey Guys,
Your XM receiver might not be getting constant power, causing it to "forget" the programming.
Also, instead of calling: www.xmradio.com/refresh
It is getting constant power.Everything checks out good in the truck.
Make sure only the yellow wire on power lead to XM unit has constant 12+ volts. The red lead is not supposed to be connected to ACC when using the IP Bus. I found that head unit retains the preset channels even upon reset or physical power disconnect - so I would be it something to do with power to the XM unit... Sorry nothing better to offer.
