Questions
By LostHIlls · May 09, 2007in Hacks/Mods💬 2 posts👁️ 949 views
Posted May 09, 2007 · 16:33 UTC#1
Whats up guys, newbie here! I have a couple of questions I need an answer to. What do you gain by bypassing the yellow and light/green wire? Can you watch movies and access navigation by doing the bypass?
Also, what is the best way to hook up an MP3 player? Can you use the AV jack in front or is it better to hook up an rca cable to the back?
Posted May 09, 2007 · 18:36 UTC#2
We really should create a sticky that has all the general questions answered....
This bypasses the system check for the parking brake. The system requires you to engage the parking brake to watch movies. By bypassing this check, you can watch movies without the parking brake being on and while moving.
You can watch movies and access navigation anyway. The bypass allows you to do that WHILE moving.
iPod with the iPod cable. Or, you can use the aux input cables on the front of the D3
As stated before, use the aux jack in front for easy hook up. For a cleaner look, you could use the a/v harness in the back.
