vss wire ... 2004 Grand Prix
By jpfay · May 10, 2007in Vehicle Specific Wiring💬 5 posts👁️ 1,702 views
Posted May 10, 2007 · 22:06 UTC#1
Looking for the vss wire on my '04 Grand Prix. It has the 'speed compensated volume' option on the stock cd player. So I am assuming it is one of the wires in the smaller wire harness that used to go to the factory radio. I just need a little help on which one. Not about to just clamp into one and hope for the best.
Posted May 11, 2007 · 00:44 UTC#2
Speed Sense dk. green TAC module, pin 4
Notes: The TAC (Throttle Actuator Control) module is on top of the engine on the throttle assembly.
Posted May 11, 2007 · 01:58 UTC#3
excellent..!! thank you!
Posted Apr 29, 2010 · 03:28 UTC#4
I'm also looking for the VSS wire. Here is the engine compartment with the engine cover removed. I think the TAC module is the black box on the center right of the photo, which falls between the air intake and the supercharger. You can see that I pulled back the wire cover going to the harness.
Based on cntrylvr79's description, I think VSS is the green wire in the picture below. Can anyone who has already done a Grand Prix install confirm this? Thanks!
Posted May 05, 2010 · 02:39 UTC#5
Ok, I've finished my install and I can confirm the VSS wire is the green one pictured above.
