GPS tracking issue at start up??
By touchmyleftone · May 11, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,251 views
Posted May 11, 2007 · 21:44 UTC#1
Hello, first post here, and just wondering...whenever I start my car and begin to drive, it takes my z-1 anywhere between 20 seconds - 2 minutes to actually figure out where I am...After it figures it out everything works perfectly, but it is very annoying that my navigation is useless until I drive around for a few minutes. My antenna is located on my dashboard passenger side on top of the metal plate, and under the connection I always have full or almost full GPS signal strength...any ideas??
Posted May 11, 2007 · 22:04 UTC#2
There is always an uncertain amount of acquisition time to acquire the GPS signal upon startup. And the time varies due to overhead clearance and such. Remember, the unit needs to acquire a strong signal from several satellites a couple thousand miles away in that thing we call space to be able to properly triangulate your position. Thats just how GPS works, no matter which brand name makes it.
Posted May 12, 2007 · 00:48 UTC#3
yeah, my z1 does the exact same thing. its nothing to worry about
Posted May 12, 2007 · 00:59 UTC#4
Yah, my old garmin 8 channel used to take up to 20 minutes to actually acquire enough signals from the sats to know where it was. These new models which acquire within a few seconds are much nicer.
Posted May 12, 2007 · 15:57 UTC#5
Your Z1 Should "remember" where you were prior to being shut off. with that and the vss/gyros, it should be able to figure out where you are and where you are going while it aquires the GPS signals.
Posted May 13, 2007 · 05:50 UTC#6
Is your VSS wire hooked up?
that solved that problem for me.
Posted May 13, 2007 · 15:38 UTC#7
haha i havent the slightest idea if the vss wire is hooked up...but my nav system does recognize speed and such (if i go to that screen it tells me how many mph im travelling and such)
Posted May 13, 2007 · 21:37 UTC#8
Menu - Settings - Hardware - Connection Status
Look at the speed sense like while moving... does the number change or is it just 0. If it moves it's hooked up.
Posted May 13, 2007 · 23:38 UTC#9
oh wow, i guess the VSS wire isnt hooked up! thanks a lot! ill get that hooked up asap. thanks so much for the help everyone!
