**SOLVED Quick question on grounding the parking break--
By gmoney863 · May 12, 2007in Hacks/Mods💬 5 posts👁️ 1,869 views
Posted May 12, 2007 · 02:47 UTC#1
The parking break lead has a wiretap on the end--can i tap into the ground from the pioneer wireharness to the aftermarket wireharness and ground the parking break that way (using the wiretap)?
Posted May 12, 2007 · 07:19 UTC#2
yes
Posted May 12, 2007 · 14:21 UTC#3
dspiel is right. You can definitely do that. If the factory harness has a ground wire, then it's usually perfectly fine to tap into that cable.
In fact, that's what I did.
Posted May 12, 2007 · 16:26 UTC#4
ditto.. i clamped both the P brake and mute wire on my D3 into the factory harness ground. works beautifully
Posted May 12, 2007 · 17:21 UTC#5
Doh I forgot to ground the mute wire--- So I can tap the ground wire with both the mute wire and parking brake wire, right?
