D3 quick question
By I8urevo · May 12, 2007in Problems/Troubleshooting💬 4 posts👁️ 946 views
Posted May 12, 2007 · 04:32 UTC#1
I just installed my D3 yesterday and bypass. Everything works perfectly. I just have a quick question though. At first when I turn on the car, it powers on fairly quickly. Starting tonight though, when I put my key in the accessory position, it starts up quickly, but when I crank and start the car, it takes a while to start back up. Is that normal or are one of the wires gettin loose?? Thank you for any help in advance. I tried searching but did not see any questions in regards to the same problem....
Brandon
Posted May 12, 2007 · 14:20 UTC#2
It shouldn't start back up. Once it has power, it should keep power until your keys turn back past the ACC. You might want to check your wiring.
Posted May 13, 2007 · 04:56 UTC#3
Normal operation nothings loose.
Posted May 13, 2007 · 18:52 UTC#4
Thanks guys!
