I managed to get the D3 installed in my lady's 2007 Saturn Vue (redline) with factory amp and subwoofer.
Works ok, and I even got the Pioneer XM tuner to use the XM antenna already on the Vue. But I have a couple questions that maybe someone could help with.
1. On-Star, supposedely the Vue is still using the Class-II data bus for the onstar. I ordered a Class2 interface from Metra/Axxess (GMOS4). but can't get it figured out. The interface has the old fat GM connector on it, but the Vue has the newer GM connectors.
2. Factory amp volume level. Is the factory amp designed for 4 volt line inputs? I ask because even with the D3 turned all the way up to 40, it seems not quite loud enough.
Any advice?
