I'm hoping some of you experts on stereo install can help me.
I'm installing an AVIC-D3 in my '06 Tacoma Double Cab. Here are the questions I have:
1. I have to hook up a constant power lead for the XM brain (GEX-P10XMT). Is it OK to just tap into the same constant power lead that the D3 is using?
2. I'm placing the XM brain under the front double cup holder on the hump. I'm just going to velcro in down and trim the support posts for the cup holder so that it will fit. Anyone see any problems with that?
3. Where should I mount the gps antenna? I've heard of people mounting it under the dash. I'm assuming this is between the HU and the top of the dash. Can I just pop it on top of the head unit itself?
4. Depending on where I mount the GPS antenna, is it a bad idea to route the XM and GPS antenna leads next to each other? Is it a bad idea to mount the antennas themselves near each other?
I very much appreciate any help that you all can give a newbie here. Also, any other tips, advice, or kernels or wisdom are much appreciated.
Again, thanks!
