HELP! IM PULLING MY HAIR OUT!
By ramman949 · May 15, 2007in Custom Backgrounds💬 12 posts👁️ 2,604 views
Posted May 15, 2007 · 04:46 UTC#1
Hey all,
I figured out how to change my backgrounds and did it! And I found all the cross threads about doing your boot up picture. But its not working for me?
Make ISO of NAV DVD
Edit ISO and swap out BGOPEN2.JPG with yours. Told leave the BGOPEN.PIM alone.
Make sure file there same size 500x240 (Same size as backgrounds right)
Make sure no lower case names
Make sure DVD copy is same name as nav DVD
Make sure to reset D2
Yet my bootup background is black only. Why?
Here is the boot up picture I wanted to use. Its the same one Im using for my backgrounds for NAV and A/V.
WHy wont it work???
Posted May 15, 2007 · 16:58 UTC#3
HELP ME BUMP!!!
Posted May 15, 2007 · 17:11 UTC#4
It's only 8KB, something is wrong.
Posted May 15, 2007 · 17:17 UTC#5
:D yeah!
Finally someone! Thank you SO much Jason. I wondered about the size myself, but didnt know how to make it larger in size.
I used photoshop and created a 500x240 canvas. I then dumped Black into it to make it back background. I then added the STI logo. Saved it as a JPEG and it saves as 38kb.
Whats odd, I have 2 of these DVDs I made and one of them has the picture as 8kb and the other DVD shows it as 38kb.
Yet both of them dont work. Here is the second DVD disk I made and the pic is 38kb this time...
http://i10.tinypic.com/4zye5a0.jpg
What should I do? And if the same pic worked for my backgrounds, why wont it work for the boot up image?
Thanks man!
Posted May 15, 2007 · 17:39 UTC#6
Just tried my DVD with the 38kb jpeg and it still wont load it. Even after hitting reset for 30 seconds. Its just blank black. Which is better than nothing, but still.
Again, this is the same photo I used for the normal background, but in its native jpeg format, not the PIM format for the backgrounds.
Posted May 15, 2007 · 18:11 UTC#7
ANyone? SOS! HELP!
Posted May 15, 2007 · 19:36 UTC#8
Upload the exact BGOPEN2 jpg you are using and I'll try it in mine.
Posted May 15, 2007 · 19:41 UTC#9
Thanks Jason.
Its at the top of this thread. Its 38KB. Im glad you noticed one of my screen shots showed it only being 8KB. Which is was on that DVD. I have like 8 of them now. But the one Im currently messing with is 38KB
Here is a screen shot of the actuall CD I am using now (or trying to use)
Posted May 16, 2007 · 03:03 UTC#10
I didn't think it was possible, but I get the same thing. A solid black screen. Something about that image isn't right. I'll make a new one tomorrow.
Posted May 16, 2007 · 05:16 UTC#11
Thanks for your Help Jason.
I finally got it to work. cntrylvr79 mentioned to make sure the JPEG was NOT progressive. When I went back into photoshop, I noticed that I had saved them progressive. So I saved them without that option on and BAM it worked. Thanks cntrylvr79!!! And thank you to Jason!
Boot up screen things to know
BG is the folder
BGOPEN2.JPG is the file to swap (Keep same name and in CAPS)
500x240 72dpi
Save as JPEG (not progressive)
Load into NAV
Reset NAV
Done.
Posted May 17, 2007 · 00:13 UTC#12
Cool glad it all worked out for ya.
