d3 bypass problem
By ryan0240 · May 15, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,019 views
Posted May 15, 2007 · 23:17 UTC#1
I am installing my d3 in the 05 gto right now. i thought i had the by pass correctly. I put the mute wire one slot up. I then grounded the end of that wire and the parking brake wire to the rest of the ground wires. Was that correct.?
when i just tried driving my car, it made me stop watchnig a movie after the car started moving and i also tried the navigation and that stopped letting me edit my route after i started driving?
what could the problem be? Please help, i'm installing right now.
Thank a lot!
Posted May 16, 2007 · 01:04 UTC#2
make sure you put the mute wire in the right spot, and that it clicked all the way in and is not loose
Posted May 16, 2007 · 01:59 UTC#3
I moved the yellow pin and i grounded both the parking brake wire and the yellow pin to the harness ground wire. is that good? i was just testing my unit and i was watching a movie over 15, then it stopped suddenly. is it just a loose connection i need to fix? also when i start up the system i get the error message about the parking brake not hooked up. if i have done it properly, i shouldn't be getting that message correct?
Thanks a lot.
Ryan
Posted May 16, 2007 · 02:00 UTC#4
yes and yes
