(the signal bounces off my shirt to the D3).
Am I the only one that thinks that a remote control designed to bounce its signals off of its user's shirt, and its usability varies with the color of the shirt you wear is a bit assinine? My steering wheel happens to be a little more upright, so the bottom of the remote is pointed at my pants - That's not an uncommon thing. Is the IR signal supposed to bounce off of my jeans?
FYI, the infrared port is located on the bottom of the SR-11 remote, not the top. Holding it directly to the D3 won't be effective if the top part of the remote is facing the D3.
Again...poor design. Wouldn't it have made sense to mount the IR port say...on the bottom SIDE of the remote control? You know, aimed at where most people will put the receiver? (behind the steering wheel, to the right usually?) Are all of Pioneer's steering wheel remotes this poorly conceived?
Oh, and another thing: the SR-11 wasn't made for the D3 so it's not going to work perfectly. As far as I know there isn't a steering wheel remote made to work directly with the D3 thusfar.
As stated previously, if the remote is pointed directly at the D3, the limited functionality works. When it is mounted according to the documentation, and for usability purposes, away from my gauges, it fails to even register volume changes. My Kenwood remote at least had a lead with the IR port teathered to it, so you could point the IR port in any direction that you wanted so it'd face your receiver. If all of Pioneer's remotes are Rube Goldbergish enough to require bouncing a signal off of a bright shirt with a steering wheel mounted at just the right angle in order to control the receiver, are there any remotes that will work with the Pioneer that actually have the IR ports pointed where they should? Do any of Pioneer's other remotes?
