Need help with Navigation
By dbird35 · May 17, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,074 views
Posted May 17, 2007 · 01:37 UTC#1
I have the Z2 and When I enter a address on the Navigation it keeps saying "Route calulation is not possible" It was working fine before so I have no idea whats wrong. Can somebody help me out?????
Posted May 17, 2007 · 13:09 UTC#2
i'm goign to be doing some serious testing today. I just had mines installed yesterday, so I'll let you know.
Posted May 17, 2007 · 14:06 UTC#3
I had the same problem with my dvd80 hooked up to a 5700dvd. I was using a burned copy of the navigation disk. Turned ouot to be the disk. Are you using a burned copy? If so try the original and see if you get the same error!
Hope this helps. :D
Posted May 17, 2007 · 14:24 UTC#4
There is no disc...its a z2
Posted May 17, 2007 · 14:49 UTC#5
Hope this helps. :D
The Z2 does't have or use discs. It is all on the internal harddrive.
