I know it has been briefly discussed before that the Z1/Z2 will not allow the use of a bluetooth audio player because it lacks the A2DP and AVRCP profiles. I'm assuming the profiles are imbedded into the bluetooth adapter. Would it be possible to play BT-Audio if Pioneer either put out a firmware update for the BT adapter or if a different BT adapter was released? Again, I'm assuming any BT profiles would be on the BT adapter and should have nothing to do with the actual head unit, but I'm not sure. I'm just curious because my 2006-model Premier DEH-P980BT allows BT-Audio and so does this year's D3. You figure Pioneer would also allow that feature in their top-of-the-line model. I just bought two new LG Chocolate phones and would love to be able to play MP3s wirelessly at my selected bitrate, not the 128Kbps or whatever it is the Z1/Z2 rips the CDs at to the library.
Posted May 18, 2007 · 01:40 UTC#1
