I want to back up my nav disks...
By dub · May 18, 2007in Problems/Troubleshooting💬 15 posts👁️ 2,721 views
Posted May 18, 2007 · 14:04 UTC#1
can someone tell me exactly how to do this?
Posted May 18, 2007 · 15:11 UTC#2
Download http://www.mrbass.org/dvdrip/
You will need a dvd reader in your PC.
Posted May 18, 2007 · 18:40 UTC#3
ok I have dvd decryptor so is this exactly what I do
1. open dvd decryptor
2. insert nav disk
3. select read from the mode menue
4. hit the "go" button
5. select the .iso from the folder I saved it to
6. burn the disk using nero?
when I use nero what do I burn it as?
do I burn it as a dvd or a data dvd?
Posted May 18, 2007 · 19:01 UTC#4
Select open file and point it to the iso. Or you can use dvd decryptor to burn it.
Posted May 19, 2007 · 01:40 UTC#5
so I copied the disk using dvd decrytor and I got 2 files. One file is
6.46 GB (6,938,918,912 bytes)
the other file is
8.22 KB (8,424 bytes)
what one do I burn? Do I just burn the 6.46GB file using dvd decryptor? It's already in ISO file. I just dont want to mess up these expensive disks
Posted May 30, 2007 · 02:40 UTC#6
Just open up disc copy in Nero. Worked perfectly, no extra steps needed. You must have a Dual Layer burner in your computer for this to work properly though.
Posted May 30, 2007 · 07:23 UTC#7
The data disks for the D3 are dual layered?!?!?!
Posted May 30, 2007 · 23:53 UTC#8
Yes and a new Pioneer DVR-112D dual layer DVD burner is $34 from Newegg so its not a big deal.
Posted May 31, 2007 · 01:28 UTC#9
Thank you!!!^^^ :x For the hundredth time ive repied in reference to this! You dont have to do any special steps to this, just use the copy feature in your burner app! Thats it people!!!
Posted May 31, 2007 · 02:43 UTC#10
Yes. I don't know why all these people are using DVD Decrypter for ripping a DATA dvd. DVD Decrypter should only be used for movies, not data.
Use a real burning program like Nero or Alcohol or any other burning app.
Posted May 31, 2007 · 02:49 UTC#11
For some reason, when I use Nero's copy feature, my D1 won't accept the disc. Thats why I use DVD Decryptor in the tutorial.
Posted May 31, 2007 · 13:22 UTC#12
Absolutely DVD Decrypter is used for data dvds as well and works MUCH better than crappy Nero. I used DVD Decrypter to rip the dual layer DVD, then use Alcohol120 to mount it back to a blank dual layer dvd.
Posted May 31, 2007 · 13:45 UTC#13
That's interesting. I don't really use Nero to copy discs. I use UltraISO to create an ISO and then burn it with Nero.
Nero is really good a burning images (created by standard tools). But it isn't very good at making images or copying.
Alcohol is good too, but not for dual layer images.
If DVD Decrypter works for ya, go for it! But I like to recommend the big boys because they are good for other stuff too. :)
Posted Jun 04, 2007 · 14:16 UTC#14
Confirmed. i just used the copy disc feature in nero 6 and my disc is working great..!
Posted Aug 17, 2007 · 06:01 UTC#15
Busted! Nero 6's disc copy feature sorta worked - the maps and everything were fine but I couldn't input addresses or anything. Spent 4 hours quadruple checking my wiring, then booted up with the original discs and everything worked!
Currently trying out DVD Decrypter - hopefully no more $3 coasters. :?
scurvy
