Problem backing up nav disk....
By stevesporttrac · May 18, 2007in Problems/Troubleshooting💬 12 posts👁️ 1,912 views
Posted May 18, 2007 · 15:12 UTC#1
Hey Guys,
I searched around on how to backup the nav disks. I used IMGburn, which is just a newer version of DVD Decrypter ( which gave me an error when inserting the nav). I read it to an image file. Then I put in my DL DVD to burn.... got an burn error ~50% through. No big concern, because I have had some problems burning with DVD Decrypter in the past. So I loaded up Alcohol 120% Loaded the image to burn, via the .mdf file.... same problem. Any idea?
Thanks in advance,
Steve
Posted May 18, 2007 · 17:21 UTC#2
I used UltraISO to make an image. Then I used Nero to burn that image. Worked fine on memorex DL using an HP DL burner.
Check the error on the burn. I bet it's because of the DL split. When you try to make an image using something that's meant for movies, it can sometimes mess up.
Posted May 18, 2007 · 18:36 UTC#3
I am also having this problem, I put my nav disk in my comp, read it with dvd decryptor, then tried to burn the iso with nero selecting "create dvd data disk"
Posted May 19, 2007 · 17:32 UTC#4
So when do I make the split for? The error comes up around the 4+ gig mark...
Steve
Posted May 20, 2007 · 04:04 UTC#5
Don't use DVD Decryptor. It's meant for movies, not data. Use a real ISO program and a real burning program.
Posted May 20, 2007 · 05:25 UTC#6
Ok, I have MagicISO, but I'm working on getting UltraISO. What settings to do I need?
Steve
Posted May 20, 2007 · 15:26 UTC#7
DVD Decryptor works perfectly for me on the Nav discs. Just change the setting from Video to ISO.
Posted May 20, 2007 · 20:11 UTC#8
Where are these settings to change it?
Steve
Posted May 20, 2007 · 23:07 UTC#9
Mode > ISO > Read R
Posted May 21, 2007 · 01:58 UTC#10
Mode > ISO > Read R
That's what I did initially...
Steve
Posted May 21, 2007 · 11:22 UTC#11
My setup is simply DVD Decrypter and Alcohol120. Being you used two different programs to burn, I am thinking it might have to be either the media or the burner. What type of media are you using? And did you check if your burner has the latest firmware?
Posted May 30, 2007 · 02:37 UTC#12
I just used Nero 7 to burn a copy of the disk. Burned a DVD-R DL on my Pioneer DVR-112D and have had no problems at all. There is no protection on the disk so a straight copy should work fine. Might be a better idea to burn it to your HD first, instead of a 1:1 transfer.
