Yeah... It says, "RW DVD+R DL" So i dont understand what i'm doing wrong... here's the procedure i'm taking...
I sent you PM not sure if it came through...
_____________________________________________________________
I just saw you had the Avic N3 as well... I was trying to figure out if this boot screen would work for the N series as well, since most are talking about the D series Avic's. So you had most luck with Verbatim DVD+R DL I see... I used Memorex DVD+R DL and burned at 2.4x to stay slow as recommended. I'll have to try Verbatim dvd's. But you definatly got the boot screen to work?
I followed these steps, tell me if i'm correct...
1. Put the NAV dvd in your computer, and open it with DVD Decryptor.
A. Open this into an ISO file on your computer
2. Open this new ISO file using an ISO image reader.
A. I open it using MagicISO
3. Copy the files to your HD off the ISO for editing.
A. I just open the ISO and make a folder for all the ISO files to fit onto vor better organization. Plus I dont trust MagicISO's burning features. I wanted to use Nero.
4. Move all your backgrounds you want into the /BG/PIM folder (convert them to PIM's by using PIMview.exe (program downloaded that converts jpg to pim... They are all the correct demensions... favorite was added to the message)
5. Next, I have done this two ways...
A. I just moved all those files as is... to Nero, and burned the files onto the dvd... because when you look at the NAVdvd... those folders and files are all visible... 44 folders/files total (on the first view)... That didnt work
OR
B. I made the newly created dvd after adding files into PIM folder, and overwriting the openbg files, an ISO again... And then burned the ISO using NERO at 2x...
(Both times... naming the newly made DVD the SAME as the name that comes up using the NAVdiscs on my comptuer.)
All of that... i'm still lost... Advise would greatly be apprecated before wasitng more dvd's
