1992 Lexus SC300 Help!!!
By miraluna · May 18, 2007in Vehicle Specific Wiring💬 3 posts👁️ 1,103 views
Posted May 18, 2007 · 19:01 UTC#1
Can you post up the location and colors of the Reverse wire and the VSS wire for the 92 lexus SC300? Thanks.
Posted Jun 26, 2008 · 05:00 UTC#2
Help!!!
Posted Jun 26, 2008 · 05:31 UTC#3
This is as close as I could get to your car.This is for a 1991 but it may be the same color and location as your car.Check with meter before you connect the wire.You can run a wire to your backup lights for the reverse wire.
VSS Wire Silver/White Behind Glove Compartment Pin 12 of ECM
