BlueTooth won't Pair to Phone
By jjlay · May 18, 2007in Problems/Troubleshooting💬 2 posts👁️ 777 views
Posted May 18, 2007 · 20:48 UTC#1
I just recently had a D3 w/ a BTB200 installed. I'm having issues getting the phone to pair. My phone detects the BTB200, but when I enter the default code in as the Passcode Key, the phone doesn't successfully pair. I called Pioneer Support and they said that it should be working. Thanks :?: Any ideas???
Posted May 20, 2007 · 00:53 UTC#2
If you are attempting to pair through the registration setting in the deck, try to pair using the phone instead. I have the Z1 and I have to set my Verizon XV6700 to search for blue tooth signals and pair that way. I hope this is clear. Good luck.
