Playing DVDs and CD's and using nav at same time
By jhershorin · May 19, 2007in Problems/Troubleshooting💬 6 posts👁️ 890 views
Posted May 19, 2007 · 00:33 UTC#1
I know the unit is supposed to be able to store nav dvd info so you can take the dvd maps out and play movies and cd's and stuff but when i take out the nav dvd it zooms out and can't show map detail...i did the bypass and it works great...just wish i could figure out why i can't take the nav dvd out to play cd's and still have nav working
Posted May 19, 2007 · 01:12 UTC#2
When you program in a route, it stores it in memory. If you don't have a route programmed in, it zooms out
Posted May 19, 2007 · 13:18 UTC#3
so if i want to listen to cd's i wont have nav until i program a bunch of routes? thats terrible :(
Posted May 19, 2007 · 16:41 UTC#4
Time to blow $100 on that ipod and solve your problem
Posted May 20, 2007 · 00:21 UTC#5
Or one of them there old fashioned cd changer dealies.
Posted May 20, 2007 · 03:24 UTC#6
Program a route at the zoom level you want then ejest the disk. Then you can cancel the route and it will remain at the preset zoom level. It will however after some distence start to show the end of the map at which point if you drive off you will run off of the end of the earth and die!!! :twisted:
Na!! it will just zoom out. :D
