switch for VSS??
By hartung14 · May 20, 2007in General💬 6 posts👁️ 1,281 views
Posted May 20, 2007 · 19:49 UTC#1
I just had my N3 installed yesterday. the switch was flipped but im not sure if they grounded the parking brake wire. I'm still able to watch a dvd while driving though. I think it's due to a switch under the dash that appears to be connected to the VSS wire. when I push it it says watching video is strictly prohibited or something like that. is this normal? I cant test the VSS becasue i dont have the nav disk but it looks like to check i'd have to have the disk and see if the VSS works without the switch on.
also on an '02 f150 supercrew, where would be the normal install location of the brain?
Posted May 25, 2007 · 02:22 UTC#2
a switch on the vss would not work
Posted May 25, 2007 · 06:09 UTC#3
Why on earth would you want a switch in the VSS wire? Just connect it properly
Posted May 25, 2007 · 12:16 UTC#4
because he thinks that its gonna trick the unit into thinking the car is not moving
Posted May 26, 2007 · 22:30 UTC#5
I didn't do it. the shop where i got it installed did. it turns out it's not the VSS. its a pink wire that me and another friend who works at a differnet shop mistook for the VSS. I still dont quite understand it though. its a pink wire with a button on it and when the button isn't pushed the unit is bypassed but if i push it i get the THIS IS ILLEGAL message
Posted May 26, 2007 · 22:31 UTC#6
