I installed the Z1 in a Charger SRT8.. I first hooked it up w/o a VSS signal, and everything seemed to work pretty well. Shortly after the install ( i.e. a week ago ) PAC Audio released their C2R-CHY unit which gives, among other things, a VSS output.. So I picked one up and re-worked my install.
Now that I've got the VSS output hooked up, when I go through a tunnel, the position indicator tracks off out into the water ( where before I hooked up the VSS Wire, it tracked along the road )... And, the Vehicle Dynamics screen reads very erratic. The S Acc, and Acc G-meters bounce around like I'm slapping the unit around or something, even though I'm just driving straight down the road at a constant speed. Even when I'm sitting still, I get G-force readings..
See this image... I'm sitting in the drive way w/ the unit. (Click the image for a full 4 Megapixel image.. BIG!)
Notice, the right meter reads -0.02g and all the rest are zero...
It's much more erratic than that on the road though... sometimes it spikes to a full G when there's no change of momentum in any direction...
Should this all settle out when the 3d Hybrid calibration is finished?? Or does it seem like an erratic VSS Signal?? And could the VSS Signal really cause all of this??
Any assistance is greatly appreciated...
LK
