d1 gps position off
By pb2624 · May 23, 2007in Problems/Troubleshooting💬 5 posts👁️ 825 views
Posted May 23, 2007 · 00:24 UTC#1
My d1 in map mode is a little off. It shows right area and street but the cursur is about 1/8 of a inch off the actual street you are traveling on. Is there some calibration that need to be done to fix this issue? Fine if you know where you going but a real pain if you are using it to rte you and it doesnt register you are on the correct street. Thanks for any help
Posted May 23, 2007 · 00:42 UTC#2
is your vss connected? and where is your antenna mounted?
Posted May 23, 2007 · 00:54 UTC#3
the vss has never been connected and the antenna is on the roof. Never had any problems until today.
Posted May 23, 2007 · 03:37 UTC#4
book says over time u can develop anomalies when the GPS and VSS arent connected and talking...
id connect your VSS and do some driving and see if that tightens things up
i had a similar issue... for about 2 weeks ive been driving around on a busted GSP antennae and finally the other day i noticed where i was VS roads didnt correspond... sure enough that was why... i fixed the issue today and so far things seem to be correcting themselves
Posted May 26, 2007 · 00:25 UTC#5
If you go in to the hardware setup screen, there's the "modify location" which will allow you fine tune your actual location on the map. I've heard that it works quite well. Personally, mine seemed to be fine, and a heck of a lot more accurate then the portable unit I had before this.
