Hey guys, I'm about to buy myself a D3, and am trying to do all my research before hand, and have a couple questions.
1. I read that the VSS wire is quote "Speed Sense red/yellow abs and traction ECU". So this means it is the red/yellow wire that is connected to the traction ECU? I tapped into an ECU fuse/power source before, and very bad things happened. Will this one be safe? When I tap it, do I just use the T-Tap type connectors?
2. Where is the Reverse Light wire thing?
3. Does anybody know if the illumination wire is orange/white or just orange?
4. I still don't have my D3, so I'm a little confused about the bypass. If I connect the Mute wire to the other pin, how will I ground it? Is the other end, as well as 1 end of the parking brake wire free? Is it safe to use 2 T-Taps to connect both the Mute and PB wire to the black ground wire in succession ( --Tap-----Tap-----()spade ) and then ground that black wire?
My wiring harness also has it's own ground wire, but I don't know how that gets grounded yet. So would I connect the D3 black wire to the harness, than the harness to whatever need be?
Ex: ------PBtap-----MUTEtap-----==solder==------wiring harness ?
Thanks for the help! I can't wait until I install this thing ![]()
Andrew
