Somebody Please Help
By dbird35 · May 23, 2007in Custom Backgrounds💬 3 posts👁️ 1,361 views
Posted May 23, 2007 · 17:35 UTC#1
How do I make/install custom back ground in Z2. Somebody please help
Posted May 23, 2007 · 18:39 UTC#2
There are plenty of threads regarding this subject which is also covered in the owners manual. If you have a specific question after reading the various threads I am sure someone will answer it.
Posted May 23, 2007 · 19:00 UTC#3
Well im not the best at this but the way im doing it is I went to download.com found a program that edits images called Corel its free to try for 30 days which gave me enough time to do mine and play around with the program from there all it takes is a lil bit of play with the program and some common sence also one thing that I found out is if you set your pics @ a 500x240 pixel ratio they look the best.
hope this helps
