ford install help...
By USAF_NAV · May 25, 2007in Problems/Troubleshooting💬 6 posts👁️ 980 views
Posted May 25, 2007 · 21:11 UTC#1
I have a 00 Ford EB Explorer that came with all the bells & whistles on the factory system, incl a 6-disc changer in the center console. Well after the display went bad & the on button quit working I bought a used N2.
I got it installed ok, incl the bypass, however, is there a easy way to hook up the ford 6-disc through the IP bus?
Right now I have an extra plug floating around that I assume goes to the 6 disc, although I haven't researched the wiring diagrams. I thought I might bypass a lot of research w/the help of you guys. Thanks.
Posted May 25, 2007 · 21:25 UTC#2
You can't. The communication protocols are completely different, and no one made an interface to connect the 2.
Posted May 26, 2007 · 02:12 UTC#3
yeah, your beat on that one. but you can probably get a pioneer changer for about $100. and it will fit right in your console as well
Posted May 26, 2007 · 03:09 UTC#4
Like a glove. Love putting changers there.
Posted May 26, 2007 · 15:07 UTC#5
thanks for the help...I was afraid of that. Well, since I'm changing out the system, might as well go the whole way! Does pioneer may a dual dvd/cd changer? That way I can just leave the navi dvd in the head unit. Thanks.
Posted May 26, 2007 · 17:43 UTC#6
Pioneer XDV-P6 6 disc dvd changer, but it costs almost $500! :shock:
