04 Corolla/Z1 Install Questions....
By iceb8 · May 25, 2007in General💬 2 posts👁️ 639 views
Posted May 25, 2007 · 22:17 UTC#1
Just found a brand new Z1 at circuit city and am in the process of installing it with the bypass... couple questions:
1) Anyone know where to connect the VSS cable on a Corolla (where the speed sensor unit itself is located)?
2) The bypass requires the grounding of the "relocated" cable, the AVIC black ground cable, as well as the grounding of the light green parking brake cable. Is it sufficient to connect these three to the vehicle's grounding wire on the wiring harness or is it just too much for a secure connection?
Thanks for any input....
Posted May 26, 2007 · 02:15 UTC#2
Speed Sense purple/white ECM, second plug from right, pin 17
The ECM (Engine Control Module) is behind the glove box.
the grounds are fine like that
