Does anyone know what the reverse wire color is in the 2007 Honda CR-V? any help would be greatly appreciated. I do know the VSS wire color, is a blue wire behind the radio in the main wire harness.
Posted May 26, 2007 · 02:21 UTC#1
this has been posted try searching, i recall it being in the driver side kick area.
i know i saw it before, i tried searching for it and i still cannot find it. Someone said it was behind the radio, but it just cant remember the color.
The reverse wire is Brown coming from the fuse panel on the driver side.
The VSS wire is dark blue in main radio harness.
For those using steering wheel interface, pink in second harness. If using PAC interface: use white, red, and black wires. White goes to pink, red to accessory, and black to ground. For "mode" to work on the steering wheel a 5100 ohm resistor is need between the white and black wires on the INTERFACE side.
