alternator whine
By LiquidTension · May 26, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,137 views
Posted May 26, 2007 · 07:52 UTC#1
sorry if this has been covered, but I have about 5 minutes of battery on my notebook so this is it.
just installed a D3 in a tc with some Infinity Components and now im getting an alternator whine.
should i?
1) buy a cheap noise isolation adapter?
2) find a better ground for the head unit and amp (the amp is definatly grounded to the chasis via large trunk bolt
3) grounding kit? could that help?
how about other ideas?
Posted May 26, 2007 · 11:25 UTC#2
Check all your grounds
Posted May 26, 2007 · 12:47 UTC#3
did you run your amp power wire and rca's down the same side of the car?
Posted May 26, 2007 · 16:27 UTC#4
I'm getting the same whine from Alternator... Damn....
this sucks... someone grounded my RCA's but there is still some left... :?
Posted Jun 10, 2007 · 06:59 UTC#5
im still getting alt. whine from my speakers..its really annoying my sony deck never had that problem..and my batteries are in the trunk and im using expensive rcas. Could it just be that a bigger ground lead is needed than the one supplied by the war harnest?
