This is probably a dumb question but I want to make sure I get it right. The speaker wire on a 2007 Frontier (from the door) is blue & red, is the red + and the blue - ?
Thanks in advance ![]()
HEre's what I have, and moved your post.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery YELLOW (+) RADIO HARNESS
Accesory GREEN/BLACK (+) RADIO HARNESS
Ground CHASSIS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED (+) RADIO HARNESS
Dimmer GRAY (-) RADIO HARNESS
Amp Turn On GREEN/WHITE (+) RADIO HARNESS
LF Speaker (+) BROWN
LF Speaker (-) BLUE
RF Speaker (+) LIGHT GREEN
RF Speaker (-) RED
LR Speaker (+) GREEN
LR Speaker (-) BLACK
RR Speaker (+) GRAY
RR Speaker (-) ORANGE
Amp Location UNDER PASSENGERS SEAT
sorry about posting under the wrong heading...
I actually need to know which wire is what that comes from your door that hooks into the speaker. I have a blue & red wire for right rear and a blue & red wire for left rear. Not sure what I have for the front since I haven't removed the panels yet. I'm sure they are the same color though.
What you can do is take a 9 volt battery and touch it to the terminals of the factory speaker. If the cone moves outward then you have the battery terminals hooked up to the positive and negative terminals of the speaker. If it moves inward, then you have them backwards. Once you have determined the polarity of the speaker, you can then hook up your new speaker.
cool, thanks for the trick ![]()
