Nightime mode on the D3 installed in the VW EOS...
By archiea · May 27, 2007in Problems/Troubleshooting💬 2 posts👁️ 880 views
Posted May 27, 2007 · 20:15 UTC#1
Hey gang...
I got the D3 installed in a VW eos and it seems that the nightime display on the map doesn't work.
thre is a menu item that selects the maps display from daytime and nightime.. that doesn't seem to work either. its eternally daytime!!
This may be related: I noticed at night that when I stop the car, put it in park, and engage the emergency brakes, that the settings menu is limited. Its not until I turn of the headlights that all of the items under settings are avaiable.. I thought the parking brake and having the car in park was enough!!!
On an unrelated issue, I notice that if my iPod suffle (newer model) falls asleep on its own, the head unit can;t wake it. I have to openthe glove compartment box, play with the menu dial to wake it and then it works....
Any suggestions? thanks!!
Posted May 27, 2007 · 23:18 UTC#2
your in the wrong section and you only have to p[ost it once. it will be found
