help with rear screen please
By Mr.Rooster · May 28, 2007in Problems/Troubleshooting💬 6 posts👁️ 941 views
Posted May 28, 2007 · 02:04 UTC#1
how can i watch tv, dvd, etc on the rear view with the front panel dimmed out. it seems when i dim the front the rear does the same. i have a z2 with a generic 7inch rear screen. using the rca cables to connect.
Posted May 28, 2007 · 10:17 UTC#2
Go to the source menu and change the rear to DVD or A/V instead of mirror
Posted May 28, 2007 · 16:21 UTC#3
i dont seem to have source menu. the 5:1 menu is grey. is it possible that the installer connected it wrong? if so how should it be. i have a z2,xm/nav traffic,ipod, gex-p6400tv, 7"generic lcd screen in the back. also this is all installed in a 2004 peterbuilt.
Posted May 28, 2007 · 18:22 UTC#4
did you enable the A/V source by any chance? by default it is off.
Posted May 28, 2007 · 19:47 UTC#5
I believe you should be able to access the source menu by touching the top left hand corner of the screen while listening to a source
Posted May 29, 2007 · 02:03 UTC#6
i got it. did not know about the left corner button. good to go for now. thanks
