2008 Ford Escape Hybrid VSS
By norrin302 · May 30, 2007in Vehicle Specific Wiring💬 5 posts👁️ 1,251 views
Posted May 30, 2007 · 13:38 UTC#1
I just bought a new 2008 Ford Escape Hybrid. I wanted to put my D3 in there, but I'm having trouble locating the wiring information. Would anybody have that or know where I coudl get it? Thanks.
Russ
Posted May 30, 2007 · 13:51 UTC#2
I don't have the 2008, but '07 is:
Speed Sense, gray/black, ABS or brake system control module
The ABS control module is on the rear driver side of the engine compartment. On the Hybrid models, the brake system control module is on the rear passenger side of the engine compartment.
On vehicles with the 6-disc in-dash CD changer, this wire is also found in the radio harness.
Doesn't hurt to check.
Posted May 31, 2007 · 01:34 UTC#3
2008 is a totally different animal. with the way most of the new fords have been, theres a good chance you dont have a speed sense. the only new ford i found it on was the edge. it was purple/orange at the pcm or the wiper motor. you could give that a shot
Posted May 31, 2007 · 12:53 UTC#4
Well it appears there aren't even any wiring harnesses or double din dash kits for the non-nav '08 Escapes yet, so I have some time. Anybody seen any harnesses or anything for an '08? Please let me know if you have. I can't seem to find any. Thanks for the info guys.
Russ
Posted May 31, 2007 · 12:59 UTC#5
no wiring info yet, but your gonna have to order the factory navi bezel from ford to do your install
