Problems with SWI-PS with Honda Pilot
By Itchy · May 30, 2007in General💬 3 posts👁️ 1,315 views
Posted May 30, 2007 · 14:46 UTC#1
I just installed the SWI-PS to the Honda Pilot. The problem I'm having is that the volume up and down buttons work intermittently. The mode, and channel up button work fine all the time, but not the volume - sometimes they work and sometimes they don't. I've reprogrammed the SWI several times and it still happens.
What do you think?
Posted Jul 01, 2007 · 01:17 UTC#2
I have a simular problem with the swsips on my Pontiac Solstice. All buttons works perfectly except the volume up which is intermittant. I emailed them and was told to reprogram and to "hold the buttons down alittle longer". I still have the problem...if you get it figured out, please post!
regards,
vtail
Posted Jul 01, 2007 · 14:05 UTC#3
Did you connect the SWI white wire? If so it's resistance based. When I turn my steering wheel it changes resistance. Try grounding your steering wheel controls to a different ground.
