How well does the ND-BT1 work?
By theblueprint · Jun 21, 2006in General💬 6 posts👁️ 1,244 views
Posted Jun 21, 2006 · 19:20 UTC#1
is it clear?
do you need to YELL in order for the person on the line to hear?
Any heavy static or air?
Posted Jun 21, 2006 · 21:36 UTC#2
I have no complaints, one person said they could hear themself, but I turned down the volume a bit and it seemed to correct it.
Posted Jun 21, 2006 · 22:21 UTC#3
Yes, because it's a full duplex system (both parties can hear each other talk at the same time) you will have to keep the volume at a reasonable level to eliminate the echo/reverb affect. Also, placing the microphone where it is not in the direct path of the speakers will help as well.
Posted Jun 22, 2006 · 14:28 UTC#4
Mine is driving me nutz. Not working well at alll with my Treo 700p. And every caller gets anoyed hearing themselfs echo. I have the volume so low I can barley hear them. I hate it right now.
Posted Jun 22, 2006 · 16:03 UTC#5
Try to mount your microphone up high and as far away from any speakers as possible.
Posted Jun 22, 2006 · 16:06 UTC#6
Something else you might want to try is covering the microphone with foam rubber. Worth a try.
