Which fuse rating
By VBLUE42 · May 31, 2007in General💬 8 posts👁️ 1,660 views
Posted May 31, 2007 · 05:24 UTC#1
Ok installers, I need your help on this one. I am going to be installing 2 amps of 600 watts combined. 1 200 mono and 1 400 watt 4 channel. I will be using 4 gage wire from the battery and 8 gage wire to the amps. I will be using AUG fusess and need to know what rating to use at the battery, 200 watt amp, and 400 watt amp.
Posted May 31, 2007 · 18:15 UTC#2
Anyone?????
Posted May 31, 2007 · 18:29 UTC#3
very simple.......just add up the combined values of the fuses in all amps and there you go
Posted May 31, 2007 · 19:36 UTC#4
Round about 80 amp under the hood. Assuming the wattages your listing are rms values.
Posted May 31, 2007 · 19:58 UTC#5
The values I listed are the max values, so would the rateing be different?
Posted May 31, 2007 · 21:29 UTC#6
Check the rating of the fuses in each amp, then add them up and get whatever you can find near to that number
Posted May 31, 2007 · 22:47 UTC#7
Use a 100amp Fuse to be on the safe side.
Posted Jun 01, 2007 · 00:31 UTC#8
Thanks all for your input guys, ill be ordering all my stuff tonight.
