VSS wire on WRX 04 sti
By scutzi128 · May 31, 2007in Vehicle Specific Wiring💬 6 posts👁️ 1,516 views
Posted May 31, 2007 · 12:44 UTC#1
Hi guys I am getting a Z1 and I was wondering where the easiest place would be for me to get to the vss wire on an 04 sti wrx. Any help would be great.
Posted May 31, 2007 · 13:03 UTC#2
Speed Sense green/yellow ECM below glove box
On the non-turbo models the vss is in pin 10 of the 20 pin plug. On the turbo models the vss is in pin 1 of the 22 pin plug. On the STi models the vss is in pin 27 of the 35 pin plug.
The vss wire is also found behind the instrument cluster.
Posted May 31, 2007 · 14:52 UTC#3
Is the ecm different from the ecu?
Posted Jun 01, 2007 · 01:12 UTC#4
its under the carpet on the passenger side, under a metal plate
Posted Jun 09, 2007 · 05:31 UTC#5
Is this the same on a '06 STI as an '04... I know there are allot of electrical changes between 2004-2005+...
thx
Posted Jun 09, 2007 · 11:43 UTC#6
06
Speed Sense green/yellow or green/black ECM below glove box
On the non-turbo models the vss is in pin 12 of the 35 pin plug. On the turbo models the vss is in pin 13 of the 35 pin plug. On the STi models the vss is in pin 26 of the 35 pin plug.
