I've been looking into these bypass modules and now have questions...what all is involved in adding these and and I better off going this route rather than rigging up a switch? If I wanted to rig a switch, how would I go about this? I'm new to this unit and its operation. Help me out guys!
avh-p7800 Park Brake Question
One side of the switch to ground, the other to the light green parking brake wire
Don't use a switch, it's pointless, just ground the green wire to the black one and done. Switches are for those pussies who actually think that a cop will pull them over and check if the unit is bypassed or not...LOL!!!! cops don't give a shit if you got video while driving. They don't even know pioneer makes navigation units. Just don't listen to these pussies that are afraid of a bypass.
Hey noob--The 7800DVD needs to see the parking brake on at startup, then off, then back on to watch video so your way is complete crap. To not have a switch would require a TR7 or one of the other PAC bypass products. Nice guess though, try that on the Eclipse or Kenwood boards
Well I got the switch put in last night and now everything works like it should! Thanks for your help!
No problemo
for the newer pioneer screens (not avics) i simply tie a relay to the remote output of the deck
so when the deck turns on it clicks on the park brake wire. works 95% of the time and when i doesnt you just turn the source off and then back on
Can also use a dei pulse timer p/n 528t to automatically do the bypass. That works all the time.
Red goes to Constant 12v.
Black goes to ground
the blue loop of wire cut and isolate the ends.
Black/white goes to the accessory wire
Yellow goes to ground
orange goes to the parking brake wire of the screen.
Set the dial to about 10 second delay.
