Z2 wont turn on
By jam996 · Jun 08, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,359 views
Posted Jun 08, 2007 · 03:25 UTC#1
Hi, I was trying to install my backup camera and while I was splice'n the power wires it short circuit'd, the nav wont turn on, I tried resetting it but no luck.
Any thoughts on what might have happend.
thanks
Posted Jun 08, 2007 · 03:27 UTC#2
have you checked all the fuses?
Posted Jun 08, 2007 · 03:27 UTC#3
check fuse bax
Posted Jun 08, 2007 · 03:35 UTC#4
Did you check the power wire with a volt meter? I accidently shorted mine to ground and i checked all the fuses. but it took me over an hour to find out my car had a third fuse for the radio hidden underneath the wiper crawl area for an anti-battey drain protection.
Posted Jun 08, 2007 · 03:41 UTC#5
Yeah, I would check your fuses.
Posted Jun 08, 2007 · 13:55 UTC#6
I will give you $50 for a dead Z2
(that way at least, I'll get an image of the drive to put on my FTP)
Posted Jun 09, 2007 · 00:20 UTC#7
yeah, I just checked all the fuses and they all work, what else could it possibly be?
Posted Jun 09, 2007 · 03:52 UTC#8
I removed the Z2 and unplugged everything, including battery. I let it be for about 20 min. and when I put everything back, It works!! I guess It needed some kind of hard reset.
thanks anyways
