Newly installed AVIC-D3 - Ipod not working
By Demolition · Jun 08, 2007in Problems/Troubleshooting💬 15 posts👁️ 1,835 views
Posted Jun 08, 2007 · 14:49 UTC#1
I'm new here and wanted to say that this is simply one awesome site.
Anyway, I just had the AVIC-D3 installed in my '07 4Runner with the Sirius and Ipod cable. My whole basis of buying this unit was so that I could keep the Ipod in my glove box and have access to all my music whenever I wanted.
Well I plugged in the Ipod (30GB video newest generation) to the cable and the AVIC screen comes up with the Ipod interface BUT there isn't any music available on the screen. It's like I'm plugging in an empty Ipod. I talked to the installer and he told me to try and update the Ipod with latest firmware (which I did) and it still didn't work.
Any of you geniuses out there have any ideas of what can be done (other than bringing it back to the installer)?
Posted Jun 08, 2007 · 14:58 UTC#2
try resetting your ipod... plug it in and format it.... then just update the library again.... does the screen say pioneer when you plug it in?
Posted Jun 08, 2007 · 15:03 UTC#3
The screen on the Ipod doesn't change at all. It's almost like it's not plugged into anything.
Posted Jun 08, 2007 · 15:12 UTC#4
check to make sure your smart installer pugged in your ipod to the right socket... the ipod wire goes directly from the back of the unit to the ipod no separate box required ... if he plugged it into the sirius then into you d3 it wont work.... and if he is just using the box verison where the wire to your ipod is white instead of black that might be the issue too
Posted Jun 08, 2007 · 15:28 UTC#5
I'll check into it westindie. I do know that the Ipod cable is the correct one (black). Other than that, we'll see I guess.
Posted Jun 09, 2007 · 01:42 UTC#6
could be a bad cable. theres only one place they could have plugged it in, so its not in the wrong spot. and if it werent plugged in at all you would not be able to select ipod from the menu
Posted Jun 09, 2007 · 14:07 UTC#7
Does the iPod show Pioneer when it's plugged in?
What file format are your audio files?
Try a video and see what happens.
Posted Jun 09, 2007 · 19:45 UTC#8
He said no it doesnt show pioneer. its like its not plugged in at all.
File format wouldnt matter, its an ipod. everything gets converted.
sounds like a bad cable/unit
Posted Jun 11, 2007 · 13:19 UTC#9
I'm having the installer take a look at it again to try and diagnose the problem.
I was thinking that there was a chance that it was the file format on the Ipod (because I've never used Itunes, just converted my CD's and downloaded other songs from other sites). Regardless, it's a pain in the a** because the Ipod attachment and interface was the sole reason why I bought the AVIC-D3.
Anyway, if anyone else has an idea, feel free to let me know. I'll also post what the installer finds out.
Posted Jun 11, 2007 · 14:13 UTC#10
In your last statement you said you have never used iTunes. That is why it is not working. If you have never used iTunes and just drag and drop ripped songs onto your iPod like a hard drive rather than using iTunes to sync them, then you iPod will always appear blank unless you access it from a computer.
Just use iTunes to sync you music like normal and you should be fine. Technically, the Pioneer logo should have shown up I imagine even without any songs, but it may require at least one song for it to show up.
Posted Jun 11, 2007 · 15:41 UTC#11
I should have been more clear about Itunes. I did use it to download the music onto my Ipod, I've just never purchased the music from them. That's why I wasn't sure if it was an issue with the format of the music on my Ipod.
Posted Jun 11, 2007 · 16:05 UTC#12
I'm pretty sure that iTunes automatically converts songs into the .mp4 format that the ipod plays. So, it shouldn't be a file format issue.
Posted Jun 11, 2007 · 17:04 UTC#13
The problom he's having isnt the format. Itunes will not even transfer a file to the ipod if the ipod dosnt support the file format. It will also not give you any error message indicating that it did nothing as far as transfering the file. This is a problom for people that download a lot of there music.
Posted Jun 11, 2007 · 18:30 UTC#14
Well I just got back from my visit to the installer. Got it figured out.
And the answer is...bad Ipod cable. Took us two hours to figure out but who cares. It works and now I'm a happy camper again.
Thanks all for the advice.
Posted Jun 11, 2007 · 22:14 UTC#15
4 hours to figure out it was a bad cable?? Wow - that probably would have been the second thing I did after checking the connections.
