avic d1 hack/bypass - please help thx
By avicd1Z · Jun 09, 2007in Hacks/Mods💬 8 posts👁️ 3,627 views
Posted Jun 09, 2007 · 15:44 UTC#1
hi,
Would you please show me where can I find out more about Avic D1 hack/bypass?
I searched and read very long time, but haven't found it yet.
thank you
Posted Jun 09, 2007 · 15:46 UTC#2
Ground the empty pin in the power harness and ground the parking brake.
Posted Jun 09, 2007 · 15:57 UTC#3
I plan to
take the mute wire out and stick it into the empty slot and ground it.
take the parking brake wire and ground it too.
is it correct? thx
Posted Jun 09, 2007 · 22:33 UTC#4
Yes, thats correct.
Posted Aug 20, 2007 · 23:40 UTC#5
thats crazy...
i've had my D1 for over a year and just found this sight two days ago, i've since completely modded my backgrounds, including my opening screen.... so this mod is next.
the parking brake thing is easy. its this mute wire thing that is something i'd have never thought of....
so you're basically making a loop out of the mute wire where its going out and that back in to the harness, then grounding the loop... essentially grounding two pins??
I want to be sure before I go fry my trip-buddy
Posted Aug 21, 2007 · 00:41 UTC#6
No loop. You take a wire that you are not using in the harness, stick it in the empty hole til it clicks in place, ground that wire, ground the light green parking brake wire. Thats it
Posted Aug 24, 2007 · 17:36 UTC#7
anyone know if software upgrades disables d1 wire hack? if i put 2007 discs in will it void the hack?
Posted Aug 24, 2007 · 17:38 UTC#8
ok....didn't read. they won't if anyone else was wondering...2007 discs will not void hack
