Installed a BTB200 on a customer's D3 to connect to his Verizon Palm Treo. Worked fine for about a month, but now there's static on the truck end (through the speakers). Its not a geographical thing. Tried resetting the BTB200. Tried re-pairing the BT connection. Tried the Echo control. Tried resetting the phone. Tried bypassing the IP-Bus past the XM module. Running out of ideas here. Everything works just as it should, and the static really isn't that bad, but it is annoying enough to piss my customer off.
Anyone else had problems with BT static in the speakers?
