Anyone try this yet?
By badbread · Jun 22, 2006in Hacks/Mods💬 10 posts👁️ 2,996 views
Posted Jun 22, 2006 · 18:04 UTC#1
Searching a elitecaraudio.com and saw this post regarding getting music on the HDD:
just use the program alcohol 120% to make images and burn them as original copies. You can d/l a free trial here http://www.alcohol-soft.com/
when you burn the image onto cd , just select "original cd" as the disc type
This may work. Has anyone tried it? If not I will try tonight when I get home.
Posted Jun 22, 2006 · 20:55 UTC#2
Yes this works. Burn 100 cd's then copy them to your Z1 at 4x the cd speed while being forced to listen to them. Other than the pain it causes in my brain to think about doing this it works fine.... :lol:
Posted Jun 23, 2006 · 02:44 UTC#3
:lol:
Posted Jun 23, 2006 · 16:23 UTC#4
Actually Pulp....you don't need to listen to them. Just pop in the CD and change your source to whatever you want. The CD will record in the background. I was ripping a cd the other morning. About half way through it, my wife comes out and starts the car to go to work. (I had it on ACC) I come out and think OMG...she's screwed up the recording and I have half a CD recorded because when she started the car, it rebooted the Z1. Nope...it picked back up right where it left off. She then switched it to XM. I thought she had killed the recording for good this time. Nope...there was a little red button in the corner of the display and it kept right on recording while she listened to XM and had the map up on display.
Posted Jun 23, 2006 · 19:15 UTC#5
That's true. You still can't change tracks or anything.
I have a couple AT3's that are partial uploads from killing the unit during a rip from a CD. I didn't care enough to see if it erased the partial recording or erased it and rerecorded.
Posted Jul 03, 2006 · 14:12 UTC#6
That's all very interesting. The Z1 is so finicky about the things that it does, I figured that if you BREATHED on it wrong, you'd upset it, & it would stop recording. That's cool to know. Oh, why to women always DO things like that?!?
Posted Jul 04, 2006 · 16:49 UTC#7
This will work but is overly complicated. I have burned MP3's to an audio CD format, as long as you put them back on in the same order and nothing has altered the length of the songs your unit should recognize the disc.
Not sure why the other forum has you image them first instead of just doing a disc to disc...
Posted Jul 12, 2006 · 00:56 UTC#8
What exactly does the alchol120 web site do for you
Posted Jul 12, 2006 · 01:49 UTC#9
It's just another burning program, like Nero or Roxio (or adaptec if you are old enough to remember that), but it is only for making copies and burning from images. In the olden days it was the best for making 1-1 copies of "weird" disks like PS2 games or whatever.
Posted Jul 12, 2006 · 02:10 UTC#10
Ok so since i already have nero i really dont need this. and do you know how to change the background without messin with the hdd
