Reverse Sense Wire
By ntrprize · Jun 10, 2007in Problems/Troubleshooting💬 3 posts👁️ 783 views
Posted Jun 10, 2007 · 03:33 UTC#1
I noticed the reverse sense wire has a resistor on it. I am in the middle of troubleshooting why my reverse camera does not come on in revers anymore. It worked fine for a couple of hours. I will pull the radio, but I need to know, is this resistor needed? Im thinking I might have to replace the wire.
Posted Jun 10, 2007 · 03:51 UTC#2
nope, you can use a 1/4 amp fuse, will do the same job.
Posted Jun 10, 2007 · 06:17 UTC#3
All fixed.. I had 12 volt in reverse at the connection to the light, but no voltage registering at the unit. No blown fuses, so a little wierd. Then I noticed that the resistance measurement was a short. So, even though it didnt blow a fuse, I was able to track down a pinch in the wire. The only spot that I forgot to zip tie out of the way from those pesky metal interior clips endend up getting pinched.
So, a quick repair, and its all fixed. I bet that resistor was all that kept me from blowing a fuse.
Thanks for your help!
