transfering phone #s manually on the d3.
By trikkky · Jun 12, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,607 views
Posted Jun 12, 2007 · 00:24 UTC#1
ya i know probably a noob question, but i looked in the manual and saw nothing how to enter and save a # manually .. saving a # as in puttin the # in and naming that #.
i know when you make a call it goes to your call history and you can save it to a preset but idk how to save it with a name either. I just want to be able to click on phonebook and see a list of the #s i usually call.
Thanks in advance.
Posted Jun 12, 2007 · 04:33 UTC#2
bump
hopefully someone knows the answer :)
Posted Jun 12, 2007 · 05:06 UTC#3
I sent them all over through bluetooth. Not sure you can do it otherwise
Posted Jun 12, 2007 · 05:08 UTC#4
ya verizon supposely restricts anything sent over bluetooth from what motorola said over the phone today...
if the info that he gave is false: i have a verizon krzr k1m ..
Posted Jun 12, 2007 · 05:10 UTC#5
Have read about the Verizon troubles on here. I have a cingular krazr and it works great (phonebook, battery display, signal display, MP3 ringtones, etc.) There must be something you can do software wise to make the phones bluetooth work properly
Posted Jun 12, 2007 · 05:25 UTC#6
i hope there is.. hopefully someone knows the solution
Posted Jun 13, 2007 · 00:01 UTC#7
well with the help of someone whos smart with phones i figured it out...
a lot of you may know this already but for those that don't.. for those that have verizon, verizon blocks obex and the transferring of anything sent through bluetooth except for phone contacts through a certain way..
If you have a D3 and a verizon fone. make sure your fone is connected to the d3 and click on transfer phonebook. This will disconnect your phone from the d3. After that go on your phone under CONTACTs and go to the contact you wish to send then click Options>send Vcard .. after clicking send vcard it will open up all devices that you have connected through bluetooth. Just click on the d3 device and it should send it. You have to send your contacts one by one.
hope this is helpful to the ones stuck like i was.
Posted Jun 23, 2007 · 05:14 UTC#8
damn I wonder if that is what I'm going to have to do with my Sprint phone too. :cry: I just got my D3 installed today and when I try and transfer my phone book over it just disconnects.
Posted Jun 25, 2007 · 04:22 UTC#9
After it disconnects transfer the contacts from your phone to the D3
