Metra XSVI-9003 / AVIC-D3 Bypass
By bigfoot170 · Jun 13, 2007in Problems/Troubleshooting💬 2 posts👁️ 788 views
Posted Jun 13, 2007 · 03:49 UTC#1
I recently bought the Pioneer Avic-D3 from Circuit City. I got it with a free installation; I just have to by the additional parts. The install guys said that they did not have the Metra XSVI-9003 Wiring Harness and that they needed it for the install. I have a 2003 VW Jetta with a Monsoon Stereo. I ordered the part at another store.. when I get it, will I have to do anything to this for the Bypass to work? I already did the bypass to the wires in the box and I am going to instruct the installer to “Please ground the Parking Break and Mute Wireâ€. Thanks for taking the time out to help me.
Ed
Posted Jun 13, 2007 · 06:07 UTC#2
no if they ground everything right and your mute wire doesnt come loose you should be fine.... sounds like ur confused on wut a wiring harness is.... all it does is plug into ur stock plug that would normally go into your radio.... the other end is the spliced to your radio/nav system.... you could hook up a system with out using a harness but that would void the warranty on ur car ( because u would cut into the factory wiring rather than plugging into it)... and im sure you nor circuit city wants to do that
