D3 Navi map WAY OFF.
By NOIRtist · Jun 13, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,043 views
Posted Jun 13, 2007 · 16:14 UTC#1
It worked when I first installed it, but the last time I tried setting a route, it basically said I was about a mile+ off the road I was on. And its just gotten worse, I was on I-95 and it put me in the ocean. lol Now its towns over. It's like it keeps getting further away from where I actually am. Whats the deal??
Posted Jun 13, 2007 · 17:07 UTC#2
wut model??? does your antenna have clear sight to the sky.... through windows should be fine unless u have a metal based window.... if that doesnt work try resetting everything... not by just pushing the soft buttom but unplugging the unit entirely for a little while..... before you reset it take out the nav disc and then let it start up fully.... it should at least be able to see wut state your in.... then put in the disc and zoom in.... the drive around for 10 min.... if that doesnt work.... maybe bad unit/antenna
Posted Jun 14, 2007 · 17:48 UTC#3
Well I tried resetting everything, thats what the folks at crutchfield also suggested. However, I didnt unplug it. I'll try that as well. I'll also mess with the antenna. But, just resetting it didnt help.
It's the avic-d3 btw. And thanks for the help.
Posted Jun 16, 2007 · 07:45 UTC#4
yea just make sure your antenna isnt under n e thing metal.... and make sure u have good reception from the satellites....
